CLOSED - Warmoth/USACG Necks
MarshallMarshall Frets: 362
edited November 2018 in Parts £
A selection currently available together with a brief summary of vital stats:
1. USA Custom Guitars - Strat style neck -  Original Order invoice first pic (note, the Suhr peghead was changed last minute to a vintage Fender style) - this neck is gunstock oiled on the maple and has been stored unused for a couple of years. No string tree pre-fitted (staggered tuners used) and aftermarket bolt style inserts added for long term strength and stability to the heel screw holes by Steve at Manchester Guitar Tech (bolts included). Rolled edges. Tusq nut fitted by Steve @ Man Guitar Tech.
2nd neck up from the bottom in next pic:
2. Warmoth Warhead  - Strat style neck/heel with Warmoth Warhead headstock, 3rd neck (middle) in the pic above - Ebony on Walnut, Warmoth 10-16" compound radius, side adjust and heel adjust double expanding truss rod on Warmoth 'Modern construction' http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth Standard thin back contour http://www.warmoth.com/Guitar/Necks/BackContours.aspx , rolled edges, gunstock oil finish to the walnut back, 1 11/16 nut pre-fitted with superb Graph Tech Black TUSQ XL nut, 6150 stainless frets, and no inlay on the fretboard, white side dots. See invoice below:
3. Warmoth Strat replacement neck - Macassar Ebony on Walnut - Warmoth 10-16" compound radius, side adjust and heel adjust double expanding truss rod http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth 59 Roundback contour http://www.warmoth.com/Guitar/Necks/BackContours.aspx  , rolled edges, gunstock oil finish to the walnut back, 1 11/16 nut pre-fitted with superb Graph Tech Black TUSQ XL nut, 6150 stainless frets, and no inlay on the fretboard, white side dots. This neck is currently fitted to my number 2 strat and I will need persuading to part with it (money talks!). It is very very good and I won't let it go without persuasion! If someone would prefer the guitar as a whole again I might be persuaded at the right price (whatever that is!). See invoice above and pics below:
Next 3 necks are all Warmoth but haven't looked out the copy of my order invoice yet - will post it up when I do.
4. Warmoth Strat Replacement - Pau Ferro on Goncalo Alves 2nd neck down from top in group shot above - Warmoth 10-16" compound radius, vintage modern construction with head stock adjust truss rod http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth 59 Rounback contour http://www.warmoth.com/Guitar/Necks/BackContours.aspx  , rolled edges, gunstock oil finish to the Goncalo Alves back, 1 11/16 no nut currently fitted but your choice can be added as above. Standard 6105 frets.
5. Warmoth Tele Replacement - Goncalo Alves on Goncalo Alves 1st neck top of group shot above - this is a Warmoth '24 3/4" Gibson Scale Conversion neck', Earvana Compensated nut, rolled edges, heel inserts,
Clapton profile  http://www.warmoth.com/Guitar/Necks/BackContours.aspx  , Gunstock oil finish, 2 x Graph Tech string trees, Gotoh Tuner reams, 6105 standard frets and 1 11/16 nut. No fretboard inlay, white side dots. Warmoth ‘Modern construction’ with side and heel adjust double expanding truss rod.
6. Warmoth Tele Replacement - Goncalo Alves one piece vintage style neck bottom of group shot above - Warmoth 10-16" compound radius, vintage construction with head stock adjust truss rod http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth 59 Rounback contour http://www.warmoth.com/Guitar/Necks/BackContours.aspx  , rolled edges, gunstock oil finish to the Goncalo Alves back, 1 11/16 no nut currently fitted but your choice can be added as above. Standard 6105 frets. This neck has a crack at the back between the headstock and the skunk stripe truss rod cover and needs some minor repair. I will post close ups of this tomorrow and offer it at a big discount as is, or will repair for a negotiated price.
Asking:
1. £250 200 SOLD
2. £300 240 TRADED
3. £350
4. £250 200 SOLD
5. £200 160 SOLD
6. £100 -- SOLD
Discounted prices + Your choice of delivery assume PPG.
The Wilkinson VS100 in black mentioned in the Warmoth invoice above is also available at £60 + your choice of delivery and I have a second one in Gotoh's gun metal (they call it Cosmo Black but it looks like gun metal grey) also for £60 + delivery.
Thanks and let me know in pm if any questions. Cheers!
“He who joyfully marches to music in rank and file has already earned my contempt. He has been given a large brain by mistake, since for him the spinal cord would fully suffice.” Einstein
Feedback link -  http://www.thefretboard.co.uk/discussion/133389/marshall#latest
  • DefaultMDefaultM Frets: 7321
    Whats the price please?
    Think you might still be editing the thread actually. Can only see one neck.
  • Also very interested.
  • hold tight folks, the above post is currently being edited for proper posting shortly...
  • there we go... Any questions just fire away!
  • MarshallMarshall Frets: 362
    edited October 2018
    edit to add the tuners are not included with the Tele neck! They are available separately though.
    Also, the USACG neck is their AAA Birds eye maple with gunstock oil finish. Will post up further pics of backs tomorrow
    edit: Gotoh tuners as pictured on #5 neck now Sold
  • Does the USACG neck have a more traditional radius than the others?
    Hi there, yes it's mentioned in the USACG invoice :- 10-12" Compound
    edited October 2018
    Update on the USACG neck: I've measured the dimensions today with digital calipers and the quoted stats in the invoice are slightly 'relaxed with their accuracy' shall we say! I've got 1.67" as opposed to 1.65" in the invoice order (which is close to be fair but still not totally accurate) and 0.830" at 1st fret (not 0.820" in the invoice) with a taper reaching 0.925" at the 12th.
    These are reasonable tolerances relative to the original order but thought it worth mentioning. I have re-installed  the nut on that neck. Rear shot as promised:
  • gjonesygjonesy Frets: 145
    Hi
    I'm most probably interested in #6 tele neck once I see the pics of the crack
    cheers
    G
    Cheers PMd
  • jester22jester22 Frets: 127
    Pmd
    gjonesy said:
    Cheers PMd
    jester22 said:
    Pmd
    Replied
    all still available- the cracked Warmoth Tele replacement above has been estimated at almost certainly less than £50 to repair for anyone interested in that neck.
    If anyone is close but undecided on any particular neck I will consider close offers ( except possibly the ‘59 Warmoth ebony/walnut on my #2 strat !)
    edited October 2018
    #6 Sold
    20% Price drop on necks
  • FatPeteFatPete Frets: 683
    I'd definitely like No. 5, but it'll be a couple of days before I can sort it out.
    Trading feedback: Trading feedback
    PM'd re #1
    #1 On Hold
    #1 Sold
