Hey guys,
I currently have a THR10 as i wanted a cheap practice amp i could use in my flat without noise issue
I was considering upgrading it as i wanted something nicer and more serious, though obviously i still have noise limitations
Is there a natural progression from the THR? I wanted a head cab setup so i can change heads in future, and also something with strong residual values for that same reason.
On the other hand I was considering just going the kemper route where I have volume control and a load of quality tones?
Cheers for some thoughts
Whereabouts are you ? I'm in Dorset and you are welcome to give mine a try if you are nearby
I should add to the topic in general, i play mainly heavy music like metal and punk, though im also still taking lessons and learning so play some clean for practice
