FS/FT: QuickLok Z-250 Studio Desk. May Trade for Unloaded Cab SOLD
surfguy13surfguy13 Frets: 75
edited October 2018 in Studio & Rec £
Have had this desk for many years and it has been brilliant for organising my gear.  Probably the most robust desk out there and this model has loads of space.  I am 99% sure my desk is the Z-250 but can't remember now what the model number was when I bought it.  The new equivalent is the Z-250.
It's in great condition.  Obviously it is collapsible and at the moment it is collapsed and stored.  However, the photos give you a good idea of what the desk consists of.  The following is the spec. for the current Z-250 and I am almost certain that it is identical to mine:
Specifications:
  • Main shelf dimensions
  • Height from floor: 28.9" - 73.5 cm
  • Width: 44" - 111.8 cm
  • Depth: 22" - 55.9 cm
  • Thickness: 3/4" - 18 mm
  • Top shelf dimensions -
  • Height from floor: 36" - 91.4 cm
  • Width: 38.6"- 98 cm
  • Depth: 17.1" - 43.5 cm
  • Pull-out shelf dimensions -
  • Height from floor: 25.8" - 65.7 cm
  • Width: 27.4" - 69.5 cm
  • Depth: 14" - 35.5 cm
  • Frame dimensions -
  • Width: 33.6" - 85.5 cm
  • Depth of legs: 22.3" - 56.5 cm
I have added a sliding 4th shelf made of solid oak which you can see in the photos.  I have used the same heavy duty sliding bracket as the upper sliding shelf.  Just makes it a bit more versatile.  This extra shelf can be installed or not depending on your needs, there is a photo below of the desk without the extra shelf.
I managed to house an amazing amount of gear on the desk with amplifiers and monitors on the top shelf, desk and mixer plus preamp and drum machine on the large main shelf, and music/bits and pieces on the sliding shelf below the main shelf.  I used the extra sliding shelf for extra bits and then there was enough space below the lowest shelf for speaker cab/combo.
I have all the bolts required to assemble it and it is a doddle to do so.  Once put together its solid as a rock due to the heavy duty steel construction.
I'm looking for £100 for it.  Have to be collection I reckon as it would be a nightmare to pack for shipping.  I'm based in Cambridgeshire just north of Cambridge.
https://i.imgur.com/QpFzzgL.jpg
https://i.imgur.com/ciObj2l.jpg
https://i.imgur.com/5o8jl4l.jpg
https://i.imgur.com/IKLyqwo.jpg
https://i.imgur.com/Kki6JLL.jpg
https://i.imgur.com/P3DHLSF.jpg
https://i.imgur.com/JamRaA7.jpg
https://i.imgur.com/2yPsmWh.jpg
