OK, a few weeks off gigs so its time to give the flock a little TLC!!
1st on the surgery bed is my Mesa Stiletto..its probably due a revalve (Powers and Rectumfrier valve)
So...all of this Mesa nonsense/malarkey about using their branded valves with the right colours etc etc - is it complete bollocks or do I need to keep within the rules as its fixed bias ? - never really understood it!!
Amp currently has a pair of "Yellow" EL34 STR 447's in it, I have a brand new pair of premium matched JJ's here which have never been used - as they are "matched" does that mean I'm on to a winner here and I can just chuck them in?
The JJ's are labelled as PC 90.6/TC 11.7 (HotRox Premium)
Cheers in Advance me dears
I have a Bias-Rite, and have maintained non-fixed amps in the past.
Wish I'd come up with that one, I'd be a rich man!
A quick test if you're unsure...
If both look like the left, then play test and if it sounds like it should then you're good to go.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
For what it's worth I don't remember ever having a problem with any properly-tested valves in any Mesa amp - the bias is set quite conservatively so it isn't very critical - you're actually more likely to have a problem with it being too *cold* than too hot. Cold bias sounds like a raspy distortion on clean sounds at low to medium volume.
And don't bother changing the rectifier, they either work or don't work - they don't 'wear out' as such. Although a spare is useful to have if you're buying valves...
Agree about the thermionic rectifier IC and on the subject of a spare? Might be an idea to get a Solid State one? I dare say there is some change in the sound but it can live in the gig bag and will never get broken but save your A and the gig? Get a hot replacement when you can. Do NOT forget some spare fuses! Those nasty, unreliable valve things tend to eat them.
Just had a thought? Digital mains power meters are now pretty cheap. I am wondering if you could put one in the amp's mains feed and read the standing power draw then replace the OP valves and check again? No idea what the resolution is but worth a do?
Dave.
A spare is useful to have but with the Stiletto you can also use the Diode rectifier as a backup.
I have a spare Rectifier as the amp came with a complete set of used spares so I have enough to get me through a gig.
