Greetings,
My ukulele build is progressing nicely (ish), but ive hit a bit of a snag and id like a bit of advice where to go next.
The issue is that the arch I put on the back (hornbeam, with 3 horizontal spruce braces) has returned to effectively flat now that i have started carving the braces. So far, i have tapered the ends and started to round off tge edges.
I wonder what might be the best way forward?
Is it likely to be a problem if i do nothing?
Should i selectively reduce the height in the central third of the braces to try and relieve tension?
Remove the braces completely and re-do? (Really not keen on doing this as there isnt much thickness in the back to play with, and time is of the essence (its a christmas gift))
Your thoughts are appreciated
Adam
I'll have to go through my notes again, I've got to get making another acoustic maybe next year if i get time, i loved doing the braces and making the inside as good looking as the outside
(formerly customkits)
Thats pretty much the method i used, except no radius dish (as its done on the Baileys course and Cumpiano book).
Radius on the braces then glued on. I dont have a go-bar deck so used Klemsia clamps and a flexible backing strip rather than a radiused dish.
Im thinking i might just have to bite the bullet and re-do the braces as the back now has a concavity (about 1mm in the centre) where it should be convex.
Cheers,
Adam
I'm inclined to agree with you and just redo them, i know it's a pita but it'll only annoy you, it's only another days work to put it right
My main concern with re-doing the braces (the time aside) is how can I reduce the likelihood of it happening again? Taller, thinner braces perhaps? Being a uke, I don't want to too heavily brace and deaden the sound, and the hornbeam is fairly thin already so I don't want to run it through the sander again. Maybe a laminated brace with a very stiff/thin central portion?
For the next acoustic builds, I think I will make up some dishes - I have plenty of 25mm birch ply left over. I won't this year, as it would be another day of valuable free time!
Cheers,
Adam
