There be an issue where I used to plug my ipod in to something, either speakers or my laptop, or mains power, and if I hold the ipod, and rest my other arm on my guitar strings while the guitars plugged into amp etc, the strings 'burn' me.
I also noted the metal backing of the ipod would feel like its vibrating if I gently moved my finger along it.
Recently I discovered this again but using a pair of powered speakers that have a metal backing plate which its vol controls are mounted on.
If I plug these speakers in to the mains, and turn on, whilst my guitar and rig is plugged in and powered up, a buzzing occurs. Most noticeable when I touch the metal backing plate of the speakers, it gets worse.
I also noticed any metal surface on the guitar, such as the knobs or tailpiece would exhibit the same strange vibration sensation, again only ever whilst these speakers were plugged in and on.
For shits and giggles I tried touching the metal plate on the speakers, and my strings at the same time. The burning sensations happen.
Its fucking annoying right?
Leaves me having to drag my laptop out and plugging that into some other speakers over the other side of the room to enable me to play along to music whilst the speakers in question are still plugged into mains, but the laptops not. Then again I really havent investigated much, but I believe that solution didnt get me issues.
Have you another mains plug you can try?
Failing that I think theres a bluetooth or wireless device that plugs into an aux socket, and you can then wirelessly connect your ipad to it. I think blackstar make one actually.
That might solve it, unless the buzzing will still travel through the mains between amp and ipad (like it seems to in my instance as thats the only possible bridge between the two devices).
This is almost certainly a hum/earth/ground loop problem which occurs when two earthed devices, the Five and the iPod PSU are connected with an audio cable which completes the loop.
The electronics in the HT-5 are not in fact returned directly to chassis and this technique helps avoid loops but obviously not in every situation. The chassis is taken directly to earth as is required by law. There are several possible fixes.
Make sure the two devices share the same double outlet or diss' strip.
Cutting the audio screen of the mini jack cable (get a cheap one from Pound Land) you can do this with a scalpel or modelling knife. DO NOT REMOVE MAINS EARTHS.
Get a transformer isolator. About £5.00 online.
BUT! Is that a genuine Apple pod PSU? There are sheds of cheap copies about and the BBC have exposed samples that catch fire! Poor internal circuitry could cause hum.
Dave.
The mains plug does have a metal earth pin (and may have suppression components inside, I think - I've never opened one though), but the connection to the power supply itself is via a figure-8 plug.
