If you are achieving your sound going in, the recorded track should be the sound you want,
Either way, you want to be sending a mixer the tracks the way you want them to sound, his job is to balance levels and mix, but these days the lines are very blurred, and mixing can be very creative with the sounds you give them. A good engineer will have his own chain of plugs that he uses to get good results.
If you are using IR's , I suspect you could be using the first method, unless you doing some routing, so check you have got the sound you want by bypassing any plugins on your track, if you find you lose your sound, you'll need to create a stem, or bounce of that track.
