Anybody tried one? I'm looking at the new one with tempo tempo.
In my search for a quality delay with tap tempo in a small form factor I'm looking at the El cap, Diamond memory lane junior, Tech 21 Boost DLA and also the wampler. Oh and the trex Reptile 2.
Other option would be DIY but i want tap tempo and there are limited options, guitarpcb have one but they are out of stock, but also, I need probably 800ms minimum which rules that one out.
Has anybody tried any of these? The el cap is nice, I've tried that but the wampler is cheaper so keen to see if anybody has tried one.
Is a DD-20 too big for you, size wise?
Alternatively, look into the Way Huge Supa Puss - analog, sounds great, has tap tempo, subdivision, warble controls, etc. 900ms max time. Great pedal.
I tried the Supa Puss, it was a bit fiddly but it did sound good. Might try it again.
I think one of the main things, aside from smallish form factor and interesting repeats, is something that is easy to dial in and has controls that react well. I always find multi's, like the G3 and M5 I had previously, sound good but just don't react like a good analog unit.
I'm not fussed if the delay sounds BBD, or Tape, as long as it has some interesting gritty repeats if required.
Yeah I did look at those but something about them was a show stopper, think it could be the tails? I like the delay to carry on after i switch delays off, not sure if they do that. But if they do I'll take a look....
I mention the DD20 because I think the digital sounds are great, the analog sim is surprisingly warm (but not gritty), the tap works great, the backwards delay is great - I think it's a superb do-it-all and can be had for relatively low prices used.
Edited to add - if ease of use is a big seller, forget the El Cap, in my opinion.
