You assume correctly. The HSS circuit offers a slightly different set of coil permutations than the SSS circuit.
Minor wiring conversion is still simpler than constructing a new harness from scratch. The connections on the underside of the S-1 pot switch differ. The following Fender schematic diagrams are out of date but they should give the general idea.
HSS - https://p4.zdassets.com/hc/theme_assets/549136/200076499/010-1590_92Aupg1_SISD.pdf
SSS - https://p4.zdassets.com/hc/theme_assets/549136/200076499/010-1200_02A_SISD.pdf
First things first. Photograph your stock wiring before altering anything.
