Anyone run a 4010 or similar crunchy Marshall with boosts/or ODs and delays out front ?
I know the rule is if an amp is generating it's own overdrive the delays and verbs will not work so well without placement in an FX loop rather than up front. Is there a workaround to this at all.....is it really that bad with the delays and reverb FOA when the amp is cooking like this? What's your fix?
Bottom line......the Marshall is cooking enough to give you a solo tone ( with FOA boost perhaps) will the reverb and delays sound OK up front?
tae be or not tae be
Mostly by not using them in the live sound, and adding them at the desk.
Recently though I’ve been trying to run it into the high input with the gain set reasonably low (gain and master volume on about 3). I found this gives the base tone a bit more hair and depth than running though the low input. It makes it harder to set up gain pedals but with a bit of tweaking you get good tones.
I must admit that I’m not a big fan of running verbs and delay in front of the amp when the gain is dimed. I can see that it does have it’s place, but not for the music I’m currently doing.
