Unfortunately, because the crack is close to the neck joint, it would have been more reassuring if the seller had granted a clear shot of the rear of the guitar. Instead, he has "conveniently" hidden the suspect area behind an chunky strap end.
For these reasons, I would want to inspect the guitar thoroughly in person before parting with any money.
Looks great & comes with a small practice amp & multi effect pedal.
Those Epiphones got some good reviews when they came out, circa 2001?
Nice starter bundle
Also seems to be a fair bit of finish missing from where the body meets the neck..... (looks like wood filler) danger! danger!
Has what also looks to be a tipex touch up job
i don't know if it worked'but here you go.
i don't know what i'm doing'the pics didn't work.
This is how I do it just using my old iphone.
Upload a pic to imgur:
Then in Imgur, click on a picture you want to post here.
Heres an example of one of mine, this is what you'll see in Imgur once you've clicked on one of your pics from your uploads:
Clickity clack that arrow thing at the bottom and you'll see this:
Clickity clack that copy link button.
Now the image link is copied automatically for you.
Finally come onto the Fretboard and above where you write stuff you'll see this button (I've circled it).
Click that and you'll see this:
Then simply paste that automatically copied link in there and press the space bar!
Image will appear in your post wherever the 'I' curser thingy is!
Easiest to write first then make sure the curser is at the bottom of your writing, before scrolling up to click on the 'paste image' button.
Hope that helps bud!
