Anyone here able to fix a klone pedal for me?
MajorscaleMajorscale Frets: 1553
I have an ARC Klone v2. It has worked fine for years on my voodoo labs pedalpower powered large board. I recently moved it onto my mini board for an upcoming gig. On this board I use a trutone 1 spot adapter with a five way daisy chain power cable which I suspect has somehow borked my Klone. The light comes on the pedal when I switch it on, but no sound comes out...
Anybody able to help with a diagnosis and/or able to fix it for me?
Thanks!
  • timhuliotimhulio Frets: 1286
    Check/replace the charge pump IC and the opamps. These are the components most likely to have been killed by the wrong sort of electricity. If the light didn't come on I'd suggest checking the voltage protection diode too.
  • Adam_MDAdam_MD Frets: 3420
    Can it run off battery and psu?  If so does it work on battery power?
  • Same situation running off a battery. Light on, no sound.
  • Funny that no other pedal has suffered with the 1 spot power, not even a klone from a different manufacturer...
    What's the other Klone?
    Tim, it is a Pedal Projects klone. Great pedal, but the company is no more. Either way it's working fine on the mini board's power supply where the ARC clearly didnt!
    Send it our way if you like.
    Bloody hell....he's back
    I lurk occasionally... ;)
