Generally dirt - I get some fine wet and dry - roll it into a small 'fag' and feed in/out and round/round - Clean its up and removes any tarnish/ozidization - make sure you get both the inside rim of the socket and the 'spring loaded' elongated part that holds the 'live contact' of the plug - Hope that makes sense
Assume the jack plug feels snug/tight when in the socket
Assume it is not the cable as well
Is it a long barrel type jack socket ? These often go wrong and being a barrel connector you can't get to the contacts to tighten them up. Cleaning by squirting contact cleaner on a jack plug and inserting in and out a few times might help
Another trick is look on the inside and see how many contacts it has. Often standard 3 contact TRS type one's are fitted to passive guitars and only the sleeve and tip used .... but if the guitar is passive and there is a TRS type fitted you can bridge the earth to the ring contact on the socket and that will cure it if the poor connection is earth side
WD40 is not just for expelling moisture. Amongst it's other myriad uses, it is also an excellent cleaner and protects against corrosion so very likely will well work - for a jack socket may well work better than both Servisol or De-Oxit - neither are miracle products.
