The front two pots ,nearest the headstock are for the neck pickup.
Edit: That is if someone hasn't had a go at this before and fkd the thing right up
The humbucker wiring depends on which wiring scheme the manufacturer follows.
So the ones without the green tag bits are the volume and the green ones are tones?
Then the top left (with the yellow wire over it in the image) is the bridge, and the bottom left is the neck?
And i just need to solder the blacks into the correct dials and their earths onto the top of the pot?
Top is neck volume
Left is bridge volume
Right is neck tone
Bottom is bridge tone
On each pickup, the green (and bare - important) wires are soldered to the backs of the volume pots, and the black wires to the terminal of each volume pot where the wire to the tone control is also connected. (The '7 o'clock' position if you look at the pot with the terminals at the bottom.)
I paired the green and plain and grounded them to the top, then attached the black to the little circular connector on the pot, any ideas here?
