I have a 2016 SG Special HP. I like the guitar, but the combination of the huge baseball bat like neck on that model along with the G-Force robot tuners will make it try and headbutt the ground whenever played standing up. I want the least invasive way of countering this, so was wondering if anyone had purchased a dual strap for this purpose and if it worked without being a ball and chain to wear. Something like
this looks promising, but seventy quid seems a bit high on a punt for a bit of buckled leather unless I have good reason to believe it works. Thanks
I don't think there's any way of stopping neck dive apart from moving the strap buttons, and there aren't many places you could move them to on an SG.
Actually three options, Ditch the robotuners for lighter weight manual ones.
Ebay mark7777_1
https://www.andertons.co.uk/planet-waves-dare-(50dare000)-black-guitar-strap
Heavy tuners at the end of a LONG neck create more rotational force than on other guitars.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Other options:
The best approach is to remove weight from the headstock - Tronical tuners or the locking Grovers that Gibson sometimes fit are about the same weight, and can cause quite severe neck dive. I suspect some people who recommend 'holding the neck' have not experienced that degree of neck dive. You really want your fretting hand to be playing the guitar, not holding it up. Try standing and playing without a strap and see how much you ability is reduced. Of course, if you want to use the Tronical tuners (as I do), you need an alternative option.
Adding weight at the body end (cavity, strap, etc.) seems to work for some people. Adding a Bigsby did nothing to help on that '14, and personally, I'd rather not make a light guitar heavy. Also, due to the physics, you'd need to add a lot more weight than you'd need to remove from the headstock.
Grippy strap: Will help with the immediate 'drop', but it will also gradually drag on what it's gripping, so you can expect a T-shirt to get progressively dragged over one shoulder.
When it comes to construction, it could be an easy fix: I have a Supreme with a maple cap and Diablo carve - it still has neck dive (larger headstock and Grovers don't help!), but the extra body weight compensates for the heavy headstock, and reduces neck dive to a level where a grippy strap, and even 'holding the neck' are effective solutions.
The problem with discussions online is that some people simply haven't encountered the full extent of the neck dive you can get with an SG - they're not all the same.
