I'm tracking guitars through a Suhr reactive load box into logic.
Meters for tracking are all averaging -18db so am pretty sure this isn't clipping but I am encountering two different types of noise on all guitar tracks.
This is occurring on different guitars and different amps
The first noise is a high pitched digital popping sound that can occur during tracking but will appear and disappear at various points within an 8 bar passage.
Sometimes it will appear 2 secs in and sometimes 6 secs in. However it doesn't print. i.e when I bounce the isolated track it isn't there.
Another possible explanation is that your host computer is struggling to process all of your multi-track recording quickly enough.
Having said that I've just tested with a mic. Same issue - happening on mic inputs too so not just guitar..
The Suhr Reactive Load Box
The amp
Microphone / Mic Cable
Guitar / Guitar cable
Power in the room
Light Dimmer switch in the room
Therefore it has to be either the DAW, Macbook or the Firewire cable, I can't immediately swap any of these out to see if the noise persists sadly. I have also had no issues with my macbook or DAW to date so it is most likely the firewire cable.
So I suppose my question has become - Can a Firewire cable cause the noises demonstrated in the mp3 in my original post?
https://twitter.com/spark240
Reddit r/newmusicreview
spark240 said: Thanks, ordered now!
