SOLD: Laney LC30-II with footswitch: £150 ono
You should be able to see all of this from the pics, but:
Hi/Lo inputs
Twin channel (foot-switchable)
Independent bass/mid/treble for each channel
Bright switch
Reverb (foot-switchable)
Effects loop with wet/dry blend control
Connection for extension cab
Laney footswitch included for channel switching and reverb on/off
Fully working, good condition for age; bought new from Machinehead in Hitchin back in the day. Only damage is a small tear to the tolex on the amp's LHS which was patched over with black duck tape to stop it getting worse (successfully!).
Valves are essentially new - pre and power amp valves fitted for a friend's wedding in 2012, since when it has been used twice (once at church when the Lionheart futzed, and at the recent Herts jam).
Selling because I simply never get to use, so had only kept it as a backup for Lionheart. Recent purchase of a Blues Cube means it no longer even fills that need, and Mrs Snags is muttering about space, with good reason.
Collection from Hertford, or could potentially deliver if not too far away, or in a location that coincides with life (periodic trips to Abingdon and Reading area, and also to Norfolk).
Deal to be done, as I need the space ...
previously 'retsacotarts' on music radar forum
Still here. Could be taken to Sasquatch in Feb if any of the strange northern folk are interested.
I think from the thread in Amps you're looking for something primarily for home/bedroom use? If so it's probably only fair to say you need fairly understanding neighbours unless you're in a detached house and intend on keeping the volume below 2 or 3. Or to be in a neighbour dispute, I suppose
Need to demonstrate to Mrs Snags that I did mean it about trying to sell at least one guitar-related item.
Also available to Crash Test Dummies fans. No extra charge
Feedback : https://www.thefretboard.co.uk/discussion/58125/
