If your current pickups employ the solderless Quick Connect system, it would be simplicity to change to 9v pickups of another brand.
Changing to passive pickups and controls involves replacing the entire wiring harness.
The ibanez's of the vai and satriani era all had dimarzio's. Could be worth a look.
It recommend just changing the pickups. Go for either the JB/Jazz set or JB/59 set. Maybe even try a PAF Pro set to get some where near what Paul Gilbert or Satriani used.
Van Halen: A relatively low-wind probably Alnico II PAF for the early stuff, hotter Alnico II humbuckers for much of the rest of his career.
Metallica: Active ceramic EMGs. Probably not that dissimilar to the pickups you have and dislike.
Anthrax: Scott Ian uses a JB.
Vai: Most famous for using the Evolution, a high output ceramic passive.
Satriani: Most famous for using the FRED, a medium-hot output Alnico V.
Truth is you can play all the styles you mentioned on any good bridge humbucker. Just some lend themselves to certain styles more easily. Videos of Kirk Hammett with the Peter Green/Gary Moore Les Paul still sound exactly like Kirk, and those are not pickups many people on forums would mention as being typical Metallica spec.
That meant buying separately rather than the duncan distortion mayhem set.
Tb-6 for the bridge and the sh-6 for the neck.
The hetset might be worth a look. Expensive but I hear he had them designed with passive pickups in mind, so if you have the emg solderless wiring, it would be a quick swap.
Ash of Oil City Pickups really knows his stuff for humbuckers for the heavier side of things and I'd ask him what he'd think would be best for your needs.
https://www.oilcitypickups.co.uk/
I definitely agree with @Stevepage though: you'll probably take quite a hit if you try and sell the ESP; swapping the pickups out is the better option for you
I guessed Duncan AHB-1s because they have been stock on some ESP models. If the OP's guitar has been retrofitted with the first generation SD 18v Live Wire active pickups, it is understandable why they might be "too much" for some musical genres.
EMG-81/-85 or -81X/-85X is the obvious candidate.
The Seymour Duncan LWC2N neck position Live Wire Classic II humbucker does a nice PAF impersonation. The LWC2B pickup is very bright - like some old PAFs - bordering on Telecaster shrillness.
Fishman Fluence humbuckers are active but have clever mode switching to provide plenty of sonic variety.
The only active pickup tone you listed there was Metallica, EMG 81 is the right choice for that tone but the wrong choice for all the other ones.
The Fat 55s are like a slightly bigger and more even sounding PAF with a bit of extra output. It should get you closer to the other sounds you like than 81s or 57/66. If you’ve got quick connect wiring they’ll drop straight in
https://www.jacksonguitars.com/gear/shape/king-v/usa-signature-scott-ian-king-v-kvt/2848237000
