When the system is in bypass the send is not connected to anything - R7 looks to be a pulldown resistor but there's no decoupling capacitor and (unless I'm missing something) nothing to bias the switch inputs and outputs so I don't think it'll work very well - it relies on the external systems having appropriate decoupling. They ought to, but you can't guarantee it, and most systems in guitar electronics that don't have their own bias and decoupling don't play well with others.
Won't I have to put some circuitry in to prevent popping?
That should be all you need. If you want to go belt, braces and sock-suspenders then you could put decoupling caps and pulldown resistors on each input and output, but that's not normally needed because there's no internal bias - same as you wouldn't bother with that sort of thing if you were using a footswitch for the same job.
The back EMF protection is just an IN4004 or similar across the relay coil, and the power supply decoupling is just a big electrolytic across the power supply rails - have a look at Geofex for some remote relay circuits.
Not much detail on it however in terms of what transistors to use or what hex inverters
http://i241.photobucket.com/albums/ff297/Axe_meister/null_zpsf22289ad.gif
