Need A Tuner For An Epi SG
DrBobDrBob Frets: 3003
Helping a friend fix up his Epihone SG G400
and the button has come off of the A string tuner
https://imgur.com/gallery/gz0KDOT
Anyone got one in the parts bin ?
  • stuagustuagu Frets: 334
    Hi drbob,
    Does it matter what the back looks like ?
    And if havent got one exactly the same , might you be able to use a similar spare iv got , heat up the shaft , get the button off, and stick it back on the epi tuner?
    gu
  • DrBobDrBob Frets: 3003
    stuagu said:
    Hi drbob,
    gu
    Hi @stuagu thanks for responding.
    For choice you’d go for a correct replacement right ? But practicality would suggest that function over form wins so if you do have something kicking about I’d deffo be interested !
    Cheers
    Rob
    Il dig the spare tuner box out of the loft later and see if theres anything thatl possibly fit the bill...
  • FunkfingersFunkfingers Frets: 14412
    edited November 2018
    I have the exact part. Small diameter press-in ferrule. Grey-green keystone button. No logo on the gear housing, just parallel ridges.
    https://i.imgur.com/YMltPUa.jpg?1
    Cover the postage and you can have the part for free.
  • John_PJohn_P Frets: 2749
    If FF’s offer doesn’t work I probably have a spare from a Gibson LP you can have.
    The modern Gibson Kluson keystone lookalike 'heads use a hex nut and washer through from the front of the headstock. This requires a larger drilled hole than for the part in the Epiphone.
    I suspect that the OP is looking to confine the repair task to the removal of two small screws, a direct part replacement and refastening the screws.
    it seems mr funkfingers has the exact part, if that doesnt work, iv got a few tuners to try thats may or may not suit. Different colour button tho :(
    @stuagu @John_P thanks for your offers of help very grateful @Funkfingers message incoming !
    Great, well done guys!
