No doubt this has been covered before, so apologies!
I’m thinking of getting a bass - if I use a guitar valve amp with a Power Station, does this pose any risk to the speakers?
..I’m guessing it’s a ‘no’ but it might not have big enough coupling caps to do the bass justice?
So..
If I get a 300w tranny bass amp and play it at home volumes through a cab with say, 2 creambacks (either semi or closed back) am I taking a risk?
Finally, what about the tranny amp with a bass speaker in a semi open guitar cab?
cheers
Baz
Whether a 300W amp is a risk to a 2x12” with Creambacks at all also depends on the cab impedance - the 300W will be at 4 ohms, and if the cab is 16 ohms the amp will only be capable of around 100W into it anyway.
It will also be safe with a bass speaker in an open-back cab unless you’re really thrashing it. Something like an Eminence Delta 12A is rated for 400W, and you won’t even come close to stressing that at any volume you can be in the room with.
I trust the advice of this forum more than that of someone with a sales angle, but let me just play back what I was told this morning, when I spoke to a speaker vendor
I said I was planning on putting a single 12" bass speaker into a 212 which a guitar speaker in the other slot, but with only the bass speaker wired up. The cab is convertible one with 3 screw on back pieces. All for home volumes
I was told that the bass speaker wouldn't like not being in an air tight enclosure and would 'chuff' and that the non-wired guitar speaker would act as a dampener
I'm sure there's a mix of fact and up-selling in this
Options are:
1) As above - single bass driver in a closed back (but not air tight) 212 with a guitar speaker effectively acting as a baffle
2) Add a second bass driver to the cab and wire them both up
3) As above but get single piece of ply to make a solid back panel for the cab
4) Double my spend on whole new cab - likely a 210
I want a good tone, but this is only for home playing - what to do?
Baz
If the back is closed, yes the unconnected guitar speaker will try to act as a 'passive radiator' - meaning that the air pressure inside the cab will push the cone, and make it move in the opposite direction to the bass speaker. This may or may not sound good - the concept is deliberately used in some hi-fi speakers, but with a tuned enclosure so the same rules don't apply - again, try it and see. If the cab is open it won't do much, almost all the air pressure will go straight out through the back.
Adding a second bass driver would be better, but it's a lot more money for very little advantage and the cab may still not be ideal for bass - and it would defeat the purpose to some extent as it will increase the volume.
In fact, if the cab has dual input jacks you could easily wire the guitar speaker to the other one and have a dual-purpose cab.
Edit - aha, Dave posted something similar while I was still typing away . I'd forgotten about shorting the unused speaker to stiffen it too.
So that rules out option 1 ..will 2 or 3 work?
@ecc83 @ICBM - shorting the unused speaker - is this as simple as linking the pos and negative leads?
Cheap Vintage Jazz bass into EZG50 with everything at noon through a Rock Crusher
I am a happy chap - I’m sure a proper bassist would scoff, but it’s enough to keep me happy for a while.
So the dedicated valve bass amp goes on hold and I’ll get a bass DI with a headphone jack until I get up to speed - thinking the Ampeg one, but open to suggestions?
So now I’m getting a bit more enthusiastic with my bass playing (same amp - EZG50, same settings - everything at noon, but I’m just hitting harder) I’m starting to get some slightly unpleasant break up on open E strings
I currently have the middle 4” panel on the back of the cab open. Cab volume is conservatively 70l
According to the spec sheet, the Eminence Alpha 12” wants a closed cab up to 22l and an open configuration between 70 and 125l, so best I can tell, it should work as is
So I guess the question is whether the distortion coming from the amp or the speaker not being supported properly?
I’ve totally lost myself in Thiele parameter calculations and came out with needing 55l for a closed cab with 1 driver (..no idea how this and the 22l that Eminence state relate, or Whether I’m going around in circles very badly?)
Tomorrow I’ll try the cab closed back with the unwired driver shorted and hope this solves it, otherwise I think I’m getting a bass cab or small bass combo
Baz
