Two of these bad boys for sale - fully working and great sounding!
Complete with covers, power cables and poles.
Price is per speaker, Collection only due to weight.
Used with both Fractal and Kemper products!
£300 each, Collection from High Wycombe.
Portable, yet capable of producing an astonishing 131 dB SPL, the DXR10’s compact, functional design makes it ideal for a wide range of applications. Whether providing simple vocal/instrument amplification, very powerful floor monitoring or comprising a compact SR system - the DXR10 delivers without compromising sound quality and power.
Performance runs in the family, and like the acclaimed DSR Series before it, DXR Series loudspeakers offer superb high-definition sound and class-leading sound pressure levels - yet in a more compact and extremely functional design that provides a level of versatility unmatched by any speaker in its class today. The DXR Series is comprised of four full-range models perfectly suited for front-of-house sound, monitors, simple amplification, rigged applications and more. Combining the series with our newly designed DXS subwoofers will further elevate your system's performance, giving you versatile control of its thunderous bottom end. With the perfect balance of raw power and innovative speaker technologies, you can depend on DXR Series speakers to deliver the full power of your performance to every member of your audience.
Speaker type: 10" 2-way, Bi-amp powered speaker, Bass-reflex type
Frequency Range: (-10dB) 56Hz - 20kHz
Nominal coverage: H 90° V 60°
LF Diameter: 10" cone, Voice Coil: 2", Magnet:Ferrite
HF Diaphragm:1.4", Type: 1" throat compression driver, Magnet: Ferrite
Crossover: FIR-X tuning (linear phase FIR filter)
Output power Dynamic: 1100W (LF: 950W HF: 150W) / Continuous: 700W (LF: 600W HF: 100W)
Maximum output level: (1m; on axis) 131dB SPL
I/O connectors INPUT: XLR-3-31 x1, INPUT2: Phone x2, INPUT3: RCA PIN x 2, THRU: XLR3-32 x 1 (Parallel with INPUT 1 ), LINK OUT: XLR x 1
Processors D-CONTOUR: FOH/MAIN, MONITOR, OFF
Power requirements: 100V - 240V, 50Hz/60Hz
Power consumption: 90W
Flying and mounting hardware: Top x2, Rear x1 (Fits for M8 x 15mm eyebolts)
Pole socket: 35mm with 2-way features (0 or 7 degrees)
Dimensions: W 305mm (12"), H 502mm (19 6/8"), D 310mm (12 2/8")
Net weight: 14.6kg (32.2lbs)
Others Material: ABS (Matte Finish, Black)
