Oil City Pickups: More workshop clearout
OilCityPickupsOilCityPickups Frets: 10362
in Parts £ tFB Trader
Firstly the star of the show ... the serial numbered prototype Oil City Masterwound Double-X tele bridge pickup (see the Made in UK section for the spec)
This was built for promo pictures as the other prototype is in one of my test guitars. New and boxed
£65.00 delivered
StoneTone Strat set: new and boxed, with your choice of cover colours (cream, ivory or black)
Normal price for set £141.00 plus delivery.
£95.00 delivered ... thats a total Bargain!
Custom Wapping Wharf Tele bridge pickup: all alnico 5 rather than A5/A2 mixed magnets. Ordered by a customer who then changed his mind ... new and boxed
£45.00 delivered
Masterwound Summer of Love 67 Tele neck pickup ... new and boxed
£50.00 delivered
HonkyTonk Angel Tele neck pickup, new and boxed
£45.00 delivered
  • RolandRoland Frets: 8701
    Please sir, me sir. Bags the Double-x pickup. How do you want paying?
  • OilCityPickupsOilCityPickups Frets: 10362
    Paypal is fine ... I'll PM you :-)
  • If @Roland loses his mind and doesn't buy the Double-X Tele then can I please have second dibs? Failing that, then @Roland, enjoy your new pickup, you lucky, lucky fellow!
    @Roland has dropped the pennies with me now ... so that 'Prototype marked' one's gone ... but as it's a Masterwound others of it's breed will be in the Xmas sale ... probably going up on the site on Monday.as they are sooooo new. true they'll be a few quid more ... but not a lot.
  • mrkbmrkb Frets: 6793
    edited December 2018
    Any neck P90s in a humbucker sized shell?
    Karma......
    Ebay mark7777_1
    Actually yes! an alnico 3 Jazz 90 Neck in a black ring/open top cover format ... I forgot to put it up ...
    Normally £81.00 ... £60 delivered
  • robertyroberty Frets: 10893
    Digging the branded bobbins!
  • FunkfingersFunkfingers Frets: 14423
    Pics of the Stone Tone trio, please.
    Looking forward to trying it out. The Alnico combination and the tapped coils idea work so well in the Wapping Wharf that I’d like to try them in neck position too.
    I'll take some tomorrow ... but just your regular, flush pole Strat pickups ... and one Strat pickup looks much like another :-)
  • ~Hi
    ~Can I grab the Stone Tone set, please, message sent
  • How would the wapping compare to a fender broadcaster that is in the 50s Baja?
    The Wapping is a hybrid ,,, as in it's got the Broadcaster top end ... but the bass grunt of later Tele pickups ... and that's just in the standard output mode ... you get 15k of added mids and growl when you bring in those extra windings. This particular one has some top sparkle added too. it's a bit of a monster when compared to a standard Tele pickup.
  • lovestrat74lovestrat74 Frets: 2525
    Ok thanks wasn't aware it's a hybrid. In terms of wiring could it be wired to a position on a four way switch of does it require an independent switch?
    @TheGuitarWeasel Cancel the photography. :)
    In terms of wiring, could it be wired to a position on a four way switch of does it require an independent switch?
    Either of these approaches would work.
    Given the considerable difference in the two output level modes, I would be inclined to retain the CRL three-way selector switch. Connect the Double-X low output conductor to the selector switch as normal. Connect the high output conductor to a DPDT on/on switch or a push-pull pot configured to also select between the signals from the selector switch and the full output Double-X pickup, respectively.
    On a four-way selector switch, the positions would be; Neck Only, Neck + low output Bridge, low output Bridge Only, high output bridge only.
    https://i.imgur.com/gLlZKuR.jpg?1
    Chassis side pole (l-r)
    1 Neck PU
    2 Jumper to 3
    3 Jumper from 2 & to second pole terminal 5
    4 Not used
    5 Not used
    Open side pole (l-r)
    1 Not used
    2 Bridge PU low output mode conductor &  jumper to 3
    3 Jumper from 2
    4 Bridge PU high output mode conductor
    5 Jumper from chassis side pole terminal 3 & output to volume pot.
  • Thanks for the comprehensive description @Funkfingers :+1:
  • MarshallMarshall Frets: 362
    “He who joyfully marches to music in rank and file has already earned my contempt. He has been given a large brain by mistake, since for him the spinal cord would fully suffice.” Einstein
    Feedback link -  http://www.thefretboard.co.uk/discussion/133389/marshall#latest
