I've
finally decided to get a custom-built guitar, having cycled through tons of guitars, mostly PRS. I've actually settled on two keepers (a 2008 Custom 22 with a rosewood neck and a 2007 Hollowbody I - at least until the custom build is done) but still fancy getting something entirely fitting my tastes.
It will be based on Williams Guitars' lil '58 but modded:
http://williamsguitars.co.uk/electrics/lil-58/So, I've opted for the classic mahogany body/maple top. Neck will most likely be roasted maple (oiled) with an ebony fretboard. The top will use very local maple which isn't like the PRS-style tight lines which I first envisaged but something more individual - with a story. I'm going to go for a tremolo with a piezo installed, as I've fallen in love with the Helix's acoustic sound using IRs.
Now, the pickups...I'm a bit lost. PRS' 58/15LT pickups sound great in a Custom 22 I had with similar spec to above - but I can find out very little about their spec, and they're not freely available. They take high and low gain equally well and have a nice vintage sound but also capable of lovely fat rock tones. I play bluesy/jazz stuff (I like a nice warm neck pickup) but also enjoy cranking out some thrash. I'll also likely get mini toggles for coil-tapping.
Any recommendations? Or suggestions on the best wiring method for coil taps without big volume drops? The PRS 408 does it incredibly well but I think it's down to the pickup, rather than wiring - although might be entirely wrong.
I will, of course, post pics when it's done in a few months' time!
My band, Red For Dissent
IMO low output humbuckers sound shit when tapped, but if you do go that way I'd suggest push-pull pots, mini toggles are the work of the devil
Congrats on the Williams, he makes some stunning guitars
My Chameleon humbuckers have the PAF tone you're after, then in the high output mode split modes they'll retain approximately the same output level.
https://www.alegree.co.uk/collections/humbucker-sized-pickups/products/chameleon-humbuckers-the-most-versatile-humbuckers
Also, as I have recently discovered in relation to "coil splitting" with 2 Humbuckers plus 2 Volume Controls, when you "split" one or both Pickups, there's a lot less volume drop off (with both Humbuckers engaged) when unequal volumes are used.
@Alegree Sadly, I don’t think either video sells the product well. I’m intrigued, truly, and would love to give them a go but the only thing that would, for me, sell them to me is straight audio files played well. Too risky to put in this, I think, unfortunately. Message me if you want to discuss further!
And the colour will be the red of these, I think, but darker with a dark burst:
