I got a little Markbass 10" bass 45w bass combo at the weekend - seemed appropriate given I'm just starting out with bass, it sounded good in the shop and I'm short on space due to an excess of guitar gear
Volume isn't an issue, but it's either my ears or it's not very well defined on the lower frets of the E string?
I've currently got the cab up on a couple of 1" wooden slats to try and decouple it from the floor - something I've used before to help with boomy guitar cabs
So is the issue potentially a lack of amp power to cleanly drive the low end or a lack of speaker? ..if the later, I've got the options to add a second 210 cab or a 115, but which is the right way to go?
Baz
Indeed: Frequency Responce: 45Hz to 18KHz on the 110 and the 210 is the same
Bizarrely, the 115 is 50Hz to 17kHz
It won't be the amp, any modern power section will handle down to at least a low E and probably a lot lower totally cleanly until the point of clipping. It could be the cab, but if anything lifting it off the floor will probably make it worse not better. It's a good idea for guitar amps because it rolls off the fundamental, but that's the opposite of what you usually want for bass and you may find yourself turning up the lows more which will be counterproductive if the speaker is struggling.
If you do want to add a second cab, a 2x10" would traditionally be thought 'tighter' than a 1x15", but porting can reduce that as well as extend the LF roll-off point, so it may be a good idea to avoid that.
ill try dropping it off its stand tonight and see how it fares
Worth checking pickup heights as well.
Coupling the cab to the floor and flattening out a very slanted pickup have helped hugely - problem solved, I’d say - Thanks Gents!
I’m tempted to try some flatwounds - any recommendations?
