Incoming amp goodness!
FortheloveofguitarFortheloveofguitar Frets: 4291
edited April 2014 in Amps
Bagged a mint condition Blackstar HT-40 combo for only £210. Think that's a bargain. Collecting the bad boy in the morning. Chuffed :)
  • 57Deluxe57Deluxe Frets: 7334
    ...how do you know 'He' is not a 'She'??
    <Vintage BOSS Upgrades>
    I've just bought it home. It appears that the amp is in fact transgender. Who'd have thought.
  • Oh well. Amps gonna be no good to me. OD channel sounds like a bloody wasp nest. Shite.
  • thecolourboxthecolourbox Frets: 9710
    Put an eq in the loop! gives you much better control than the onboard eq
    soundcloud.com/thecolourbox-1
  • Wasp nest? That's odd. Blackstar amps are not fizzy, middy and compressed perhaps, but definitely not fizzy or buzzy...
  • FortheloveofguitarFortheloveofguitar Frets: 4291
    edited April 2014
    Probably compressed more than fizzy but I'm not used to that and sounds crap to my ears.
  • LoobsLoobs Frets: 3832
    In the skip it goes.
    Not quite but certainly I can't work with tone that bad. The clean was fine but the od just way to coarse.
    An insult to good tone
  • Most
    Definitely. I paid naff all for it and is mint, not a mark on it so should be able to move it on quickly.
    Just hope they don't read this damning thread
  • W
    wont be on sale through here anyway. Besides some people may think its a nice tone. I'm to used to my Cornfords etc. had it too good.
    from the sublime to the ridiculous
  • jonnyburgojonnyburgo Frets: 12312
    May be worth changing the preamp valves to something less gainy, I've had a few blackstars and found they are much too heavy too quickly on the OD side.
    ICBM told me to do that but I never did, i think he recommended 12at7's? could be wrong though, check first.
    "OUR TOSSPOT"
  • CacofonixCacofonix Frets: 356
    Is it a digital OD?  If not, try lower (or higher) output pre tubes.
    Really not sure if it's digital or not.
    @ICBM can you shed any light on this at all?
    Any help much appreciated before I move it on.
    It's the reverb that's digital, so changing the preamp valves should give you some variations.  They are ECC83s so you can use them in most amps if you don't like them.
    The od sounds pretty good in the mix in the attached.  The second video seems to showcase the od better than the first one.
    https://www.facebook.com/media/set/?set=vb.101737197382&type=2
    ...thought as much - is deffo a 'She'...
    edited April 2014
    This
