One observation. The Sheraton II is of semi-hollow body construction. The Gretsch that you liked is fully hollow. This has some effect on the overall sound that each guitar will produce through amplification.
I suggest that you trawl YouTube for demonstrations of the Gibson Chris Cornell signature guitar. (Essentially, a 335 with 'Trons.)
Don't be put off by the low DCR they have a big fat mag and make decent output. Both drive an amp or pedals well. The 8k ones have lots more mids. They still have the sweet harmonic thing going on. It's quite common in Gretschland to have a trad neck and the hotter 8k-ish bridge. Either way's good, I have a pair of trad-style in one guitar and a 8k-style bridge in another.
FWIIW, it is possible to obtain adapter mounting surrounds that centre a regularly-sized 'Tron onto a humbucker-sized rout. Obviously, for this to work, you have to get the correct mounting type on the 'Trons.
Original USA Epiphone Sheratons used the mini humbucker. Thus, it might be appropriate to have a pickup of that sort housed in a regular humbucker cover.
So many guitars that have been converted to Filters have strings that don’t line up with the pole peices. This always grates just a bit with me, might or might not with you
Like this (which is what you need to put mini-humbuckers in a modern Sheraton) - find image on Amazon, copy web address, click 'file' and paste web address:
