I dived into my new project a couple of months ago, full of excitement and already I was desperate to play it. Did lots of planning, drew up accurate plans, sorted some templates, built a rough working body (as I'm trying something 'different'), worked around a few problems, adjusted the concept a few times, cut out the body and neck, routed truss rod, then ....... Nothing. It has sat around for weeks and I just can't seem to get going. I'm still desperate to play it but I can't seem to do the next job, which is cut the fret slots (not a favourite job!). I took a long weekend start of December to get going. Failed. I thought this long xmas break I'd get going. Failed so far. I need to kick myself up the arse. One problem is that my garage is an uninspiring, messy, overcrowded, cold area with a leaky roof and no proper work bench. Anyone else get caught in the eternal loop of failing to do anything?
The way I get over it is to sort the task into individual, discrete jobs. Your next one, for instance, is to cut the fret slots.
Step 1: Try to forget about the project as a whole. Think about that job - and only that one - until you've done it 100 times, and encountered/solved every conceivable problem, in your head. Don't even go back in the garage 'til then.
Step 2: Then go and do the job. Or get as far as you can until you hit a snag.
Either way, then WALK AWAY and go drink beer. Your next job is either whatever you decide is next, OR solving the problem that just cropped up. Either way, repeat step 1.
Not saying it's the best way, but it works for me - if I get to think about what colour it should be, or what wiring layout to use etc etc, then I never (in this example) get the fret slots cut.
Oh and FWIW, tidying up the garage *IS* a valid job in itself!
Finally made some good progress in the lead-up to Christmas and hope to have it all done by new year. It's been a saga but NGD within sight.......
