I've noticed a rattling coming from my amp (Marshall Mini Jubilee combo) which I'm almost certain is preamp valve rattle. It happened on my old one as well, V1 went microphonic. Before I replace it I wanted to know if there's any good way of preventing it happening again? Short of re-housing it into a head shell which I've been tempted to do for a while now!
I've seen the Eurotubes damper rings but do they actually work?
https://www.eurotubes.com/store/pc/eurotubes tube damper rings.htmIf so, any UK based equivalent?
IIRC V1 has one of them metal covers on it (possibly where the rattle comes from?) - I guess that won't fit with these rings on so is there any downside to removing the cover?
This is just a problem of putting valves in a box with a speaker.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Rift Amplification
www.riftamps.co.uk
Ebay mark7777_1
Rift Amplification
www.riftamps.co.uk
Ebay mark7777_1
@mbe - are the tung sols less prone to this sort of thing then? I think the stock Marshall ones are rebadged JJs.
I don't get any rattle when the combo is plugged into a cab instead of the internal speaker btw. So I assume it's something to do with the internal speaker making the valve casing rattle still?
