So I'm just starting out with my musical adventure but I've got straight on the digital wagon,
XR18 Desk
G3XN for the for amp modeling and FX
Roland FP-50
2 Vocal Mics
PA
no cabs
no amps
no big heavy pedal boards
no analog desk
FX for vocals are all on the XR18 and can be toggled from phone, everything all straight into the desk and 2 active 15's for the PA, most inconvenient item is my Roland FP-50 for Keys. Also we're a duo so there's only 2 of us, but the stage looks a little empty sometimes.
I see so many live bands especially older groups with a 5 piece cover bands bringing
2 guitars each with cabs/amps/pedal board
bass with cab/amp/pedal board
1/2 keys with amp
drums with own mixer
big old analogue desk with separate fx and 1000 mics to mic all the amps
And end up sat thinking, that's a LOT of stuff to set up/tear down, why don't you just shell out on an XR18/X32 RACK and some amp/cab modelling pedal boards, ditch 70% of your gear and gain a ton of versatility and save your back/knees.
So whats your setup, who's old school and who's took the digital plunge?
I have noticed however some bands now have a terrible sound when listened to at the front in the middle ... purely because the lack of backline amps and wedge monitors onstage now mean anyone listening at the front ... between the PA speakers is basically just listening to a drum kit ..... further back where you can hear the PA speakers is fine but if you want a decent sound in the front middle you now need in fill speakers .... so you cure some problems but create others, such is live
Personally for me, a smallish amp and a pedal board is fine for covering most styles .... Some of the guys I work with aren't on IEM's so no guitar backline at all would be a problem for them. I fancy a Helix but not enough to buy one.
If you want to you can actually go completely desk and laptop only with no Helix or modeller ... if you route out the guitar and bass channels on the desk to ASIO you can insert you fav Amplitude amp sim in your DAW and the return is processed . Basically you have guitar DI'ed into desk ... that's it . Basically that's the future
Oh oh the joys of doing an acoustic gig with the HH Ma100 4channel PA amp and a pair of 1x12 cabinets ... we were gods! ( and the fee was the same as today!)
Getting the best sound out of the most compact, good value and modern gear really appealed to me, my gear is by no means cheap but I haven't gone crazy. When I started looking at amps and cabs I was thinking, why can't I plug direct into the desk? When I realized I could I made it my mission to keep my gear as small and portable as possible and it makes the whole experience a lot more pleasant.
The only feature I use is EQ on the Aux channel which feeds my IEMs. If I didn’t warm them up a bit then I would over compensate with the guitar’s tone control.
There are still things only real amps can do, but if your playing style doesn't involve them, fill your boots, if not your van.
I always use compression on vocals .... it helps keep the vocal consistent in level which means it sits in the mix better without having to be overly loud.
Next gig try a gentle 3:1 ratio on the vocals, medium attack speed and lower the threshold until you see about 3dB of gain reduction on the loudest sung parts. That's my go to starting point. For the kick i compress a lot harder .. I'm generally see'ing 6 or 7dB with a faster attack and slow release
IPad mix facility and dynamics are the 2 things I miss most when I'm using an analog desk, although I used a new analog Yamaha one the other day and that had comressors on every channel which was nice !
Very different playing with a band though where unless everyone has in ears or monitors we need to hear each other over the drums and finding a drummer willing to use an electric kit and everyone with in ears is a rare unless you form with that in mind so I still use an amp
If someone already has a setup they are happy with then there’s no need to move over to digital and spend more on gear - especially as some older gear is worth very little compared to the old price. Maybe when gear like desks need replacing make the switch but I can see a use for acoustic drums and small amps with a vocal PA and little analogue desk - I sometimes play with bands like that and it’s quick and easy and hassle free to just enjoy playing.
For the sake of balance I’d also add that catching an amp on axis close to the stage can be equally detrimental to a decent, balanced sound.
