Does anyone have any Practice regimes to reach there goals for 2019?
I always set new goals and write out what i need to practice then last for about 2 weeks then i get bored.
This year I'm determined to be more disciplined and stick at small things most days to get better. Eg, I'll learning one phrase from a player that grabs my ear, get inside it more, learn the note choice, learn the rhythm correctly, the feel, nuance and get my own ideas from that one phrase.
I normally try to learn a whole solo or a whole song but i often get bored so i'll going to learn smaller chunks with the hope of developing.
Do some people on here learn like this and has it worked for them?
I'll be interested to hear what anyone else is working on
Last year was full of learning little snippets of songs for me, with very little work on basic techniques. I often started with good intentions, but got bored. I think my biggest problem is I've got to be able to apply what I'm learning, so when I spend a couple weeks doing some like learning country riffs, I get a mix of bored/fail to remember them, as I'm not actually applying them.
The same applies to theory. I find that going through a basic progression/riff, and seeing how the theory applies to it, helps me actually understand, apply, and most importantly remember the theory.
However, I'm at the point where I'm considering getting some proper lessons, as I feel I could do with somebody to help me set goals, and push myself.
I don't mean ambition in the sense of being a famous, but simply having the determination to gut out the hard, boring bits- of which there are many.
You simply have to do the work.
I used to think that anyone could get to high standard of musical skill simply by doing this work.
This is still, to a degree, true, but having taught many students I've concluded that most people simply don't want to or don't have it in them to do it, so they end up kidding themselves about how much work they do, or how much it takes.
It isn't for me to tell anyone what they should or shouldn't do- but there are more rewarding hobbies if you just want to do something to fill a couple of days a week.
Music requires dedicated daily practice to get good and then stay good.
It is up you whether you want to do it.
if you where giving advice to your students and your self what would you practice and work on the most?
As to what you should practice, it depends on what you want to achieve.
If you want to be a shredder, or a blues musician, or a jazzer then you need to approach things a bit differently, although I recommend that everyone know the following:
1. names of the notes on the fingerboard
2. major/minor scales and modes + pentatonic in at least 3 keys, ideally all of them.
3. how to harmonise the major scale.
Beyond that it really depends, but the main thing is repertoire.
Too many guitarists forget to learn songs- everyone should know a lot of songs.
Try learning a song a day for a month- you don't need to learn every note, but just be able to busk it to an acceptable level.
At the end of the month you'd be 30 songs richer.
Having lessons for the last few months of last year helped me progress as it gave structure to me my practice as I had to learn things for the following weeks lesson.
I haven"t had any lessons for just over a month now & found, especially with Xmas & New Year in that time, that I hardly picked up a guitar, & when I did I just played things I already knew well.
I will be re-starting lessons before the end of this month & hopefully continuing them as it definitely stops me being lazy & gives me the motivation to learn & progress.
We are all guilty of it.
My recommendation is stick to what you want to do, don't be a butterfly. For years I flitted between playing rock, blues, jazz, classical etc and it wasn't until I decided that it was jazz or nothing that I really started to make progress in that genre. Don't get me wrong, I played in pub rock bands and was no slouch, but focussing on that one genre really made the difference.
Stick to what you want to do and don't get distracted.
BTW what are the more rewarding hobbies? Half-serious with that question..!
My YouTube Channel
- stick to one or two styles.
- Learn the major scale & its modes in all positions with root starting low E and A string.
- Learn fretboard notes (I'm still poor at this)
- Sit down little and often and just work through it. WORK!!
- Defo learn songs.
- Switch between acoustic and electric. Helps so much, for me, anyway.. improves technique, new take on things etc.
Also I realise I need to learn the pentatonics a bit more because although I know the modes near inside-out, switching between major and minor I never quite target the right "feel" - The basic pentatonic has to sit over it I now realise as just remembering a bunch of shapes isn't enough.
Also what I've found, from a technical point of view... is that a break can be a good thing. If I come back something after some time and the previous problem was tense hands/incorrect technique, that break really helps to re-focus and bring things to light... if that makes sense.
Deadlines and bands also a good motivator. And lessons (though I never really took guitar lessons - shame on me).
Defo need an inspiration and ambition as has been said. It's a solitary and time-consuming task. Truly a labour of love.
My YouTube Channel
For me there are two types of hobbies. Those like guitar which require serious effort.. and all the rest.
I've always been the sort to stick to one or two things and try to get good at those things. But I can also see that variety is the spice of life and do wonder if a happier life would be to try many different things but never become great. I think the latela might give you more frequently happiness.. but a happiness which isn't as deep and rewarding.
My YouTube Channel
So the shorter term goals is to get the individual phrases right at a tempo so the rhythm is right. So each day could be a different part of the solo for example.
Make lists as well, and tick it off once you have done it, this is more for like grades or something though. So I would say "play this scale up and down 4 times to this tempo...." once they can do it, no mistakes they tick it off. Sounds a bit strict and military but that's what grades are.
will write a list of songs that I want to learn and try to stick to them and get them gig ready!
https://youtu.be/rCUicrtYabU
This looks a good practice regime? Anyone tried?
