57 deluxe - volume problem?
newi123newi123 Frets: 860
So I recently bought a 57 custom deluxe. I'd swear it's lost some volume since I've had it - maybe 2 months.
I run it with a princeton 68, and when I bought the deluxe it seemed as loud if not slightly louder than the princeton. Now the princeton seems significantly louder. So I don't think its that I've just adjusted to the deluxe volume.
What if anything could cause this? All help appreciated before talking to the shop or recruiting a tech.
Thanks!
  • ICBMICBM Frets: 72253
    A dying valve is the most likely.
  • newi123newi123 Frets: 860
    I've swapped the power valves - would a preamp or rectifier have a similar effect? Cheers......
    edited January 2019
    It could do. Have a close look at the rectifier - there should be two filaments, like a preamp valve. If only one is working that would reduce the volume a bit, but also probably cause hum. If both are working it's probably OK.
    The same with the preamp valves, but I would expect both to look OK - if either had a dead half, either one channel wouldn't work at all, or the whole amp wouldn't. But loss of gain/performance is also a possibility.
    Ok - I do think it's down a bit on gain too!
    Thanks for your help. Always appreciated!
  • 57Deluxe57Deluxe Frets: 7332
    sorry - do I need to speak up??
    <Vintage BOSS Upgrades>
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • What speaker was in it? Jensen Alnico, Cel Blues, etc, drop volume when they break in. And then become unusable outside of a studio. Suggest you put a Cel G12H30 in there.  Strong chance it will solve the problem.  :+1:
    I've never come across that, ever - if anything they increase in volume as the cone loosens up.
  • RiftAmpsRiftAmps Frets: 3137
    +1 on what @ICBM said.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    Seemed to gain a bit when I swapped the rectifier valve.
    Hadn't considered speakers getting louder. The bench mark for how loud the deluxe is is the princeton. But I have changed the speaker in the princeton, so maybe that's got louder with a bit of use rather than the deluxe losing volume.
  • GassageGassage Frets: 30882
    You do realise the two vol controls are interactive?
    Yes - plugged into the instrument input - the Mic volume actually makes it quieter if the Mic volume is up full. Is that correct?
    Yes, c 75% is full dirt on the unused pot, IIRC>
  • munckeemunckee Frets: 12326
    As a comparison how are they. I'm currently still in love with my 68 Princeton but always fancied a tweed deluxe.
    That sounds about right - cheers!
    I'm actually much preferring the 68!
  • Modulus_AmpsModulus_Amps Frets: 2574
    When did you change the speaker and what did you put it, that could easily be the issue.
    Changed for an eminence rajun cajun three months or so ago - has been gigged regularly since then, so it's prob wearing in nicely.
