Good vid but as usual for TPS it drags on and on and on!....
Different attenuators work best with different amps - there isn’t an easy one-size-fits-all choice. So for a recommendation you first need to know what amp it’s for.
The Fryette isn’t an attenuator, although it can be used to do a similar thing - it’s dummy load and re-amp system. Much more complex and expensive, and has the advantage that you can do other things as well as just reduce volume, like run effects after your main amp. But it also completely separates what comes out of the speaker from your amp, which is now effectively just a preamp.
It's sort of weird, the Fryette came out what 2-3 years ago and it was a unique, successful idea.
I fully expected the big boys to ride in and do it better and cheaper, but nothing happened, not even smaller companies, so to my knowledge Fryette are still the only company doing a load/reamp box.
But really, its not tone we’re talking about here but volume...
guitar isn’t for the bedroom.
I’m not familiar with the Victory V30 so I can’t recommend a specific one, but someone will have tried it.
