Also, have you checked you're using the most useful signal chain on the Katana?
You may want to connect to a computer and check your signal routing and effects loop position.
I will check that later - most likely I don't have the FX loop function enabled on the HX unit.
I do have the FX loop enabled on the Katana and have been switching around for different signal chains but that hasn't helped regarding my initial problem.
