I put JJ’s in mine and they sounded fine.
How easy is it to take the chassis out?
(I've searched but couldn't fine any photos or vids online, and I'm sat day dreaming about amps whilst at work ;-) )
This applies to preamp valves even more than power valves, so if you're feeling that it's not as loud or as good-sounding as it used to be, change the power valves first. This is an amp which will need the bias checking and probably adjusting for new power valves, so you'll need to know how to do that.
In fact I started a thread soon after getting the amp and @digitalscream asked Doug at Jet City Directly about it....
http://www.thefretboard.co.uk/discussion/56428/
*Edit* P6 in the manual: http://www.synthmanuals.com/manuals/jet_city_amplification/jca20hv/owners_manual/19f8da_af5c6098cf5d721948c31c5d72006c8b.pdf
Yes, it's a fixed-bias amp, which means - somewhat counterintuitively - that the bias may be adjustable. Whether or not it needs to be depends to some extent on how conservatively it's set at the factory, but with the variability of modern valves it is not wise to assume that it won't need to at least be checked.
It's *cathode* biased (AKA 'self-bias') amps which do not need to be adjusted. 'Fixed bias' is so-called because the bias voltage is fixed by an external supply circuit and does not vary with valve current, unlike cathode bias. The bias supply may or may not be adjustable, but the Jet City is - this is the adjuster:
Whether you want to use it is up to you, but it's there for a reason.
None of the EL84s I've ever bought would've pushed any of mine over the edge, but I'd still be uncomfortable about throwing valves in there without checking bias.
It's an odd one tbh, Doug White insists there's no real need to bias, and we all know he's kind of wrong in principle but it seems to work in practice.
Me? It's a gigging amp, just do it, it only adds ten minutes to your valve changing time.
They need to be modded to be able to take the relevant measurements the "safe" way (bottom of page, cutting connections, drilling the board and adding 1 ohm resistors off the EL84s):
http://markweinguitarlessons.com/forums/threads/jet-city-jca20h-choke-mod.25897/
Didn't we discuss this very thing some months back @ICBM ? If I remember right you thought it would only increase volume or something? Damn, will do a search and come back...
You can do it by the transformer voltage drop method, which is safer and very accurate, although still dangerous by comparison with any cathode-current method.
Easiest and safest is to use a plug-in adaptor between the valve and the base, and measure the cathode current externally.
In general if the bias *is in the right range* then it only really affects the volume slightly, but that's not the problem - it's if it's outside the right range, either too hot (bad for the valves) or too cold.
It's certainly possible that you might not need to adjust it if the amp is biased cold - but it's also possible that it will be too cold, which will produce a nasty distortion that you don't want.
As p90fool says, it may not be absolutely necessary but it is still good practice.
