In fact I’ve got two - my penultimate pedal in the loop is a boost for solos, and my final one is another boost, but set to zero so when I stamp on it everything cuts out, no hiss, no hum, nothing.
Assuming you aren’t already using it, of course... but that’s a reasonable guess given that most people don’t .
Don’t use More Drive, keep the drive fairly low and the master higher and it will do exactly that.
edit: Sorry, not casting aspersions. What I meant is do you need to stand out more but the band sound stays constant or does the whole band want to be louder at that point?
In the loop (and at the end of the loop chain) it will take what you've got and just make it LOUDER (maybe a bit fatter too etc. but not change the gain/drive unless you're already overdriving the power amp and bleeding out your ears).
In the front it will up the volume and the dirt, as it drives the pre-amp harder.
TC Spark for me.
MXR Microamp is good. I know it is a one knob pedal, but it seems to add a bit of beef to the sound, not just make it louder. Don't know if that is Fletcher-Munson effect, or whether it does lift certain frequencies. Just beware the old half-assed bypass versions. I assume the bypass is fixed on the new ones?
My wife bought me a Wampler Tumnus Deluxe for Christmas. I need to play with it more, but it is a seriously good pedal, and would do the job the OP wants. I'm working out how to reconfigure my pedal board to put it on. Not sure whether to take off the Microamp clone, or the TS type.
