Help: Very loose tone pots
The tone pots on my strat are very loose. Both use push/pull to activate different pickup combinations. I prefer very stiff pots so I get more accurate changes. These are often moved accidentally and therefore unintentionally darken my tone.
Is there an easy solution to stiffening the pots?
  • FunkfingersFunkfingers Frets: 14412
    IMO, the easy solution is to control your strumming/picking hand so as not to knock the controls in the first place.
  • mrkbmrkb Frets: 6776
    Wouldn’t have thought so, the push/pull operation stops you using an o-ring or felt washer under the knob. Changing pots would be the only option, but sourcing better push/pull pots is tricky- you could move the pickup selection bits to a separate switch which opens up more options.
    Karma......
    Ebay mark7777_1
  • ICBMICBM Frets: 72253
    Try working some thick grease down the mechanism - take the knob off, pull the switch up and put the grease on the narrow part of the shaft, then push it down and wipe off any excess. Do that a few times if necessary and see if it helps.
  • lukedlblukedlb Frets: 488
    Trust me, it takes the slightest brush to move it. I’ve never had the problem before. I play with a very rhythmic right hand. I do try to take care but that’s the last thing I want to worry about.
    What about a washer with a reduced hole so that it grabs the pole?
  • RolandRoland Frets: 8693
    One method of stiffening knobs is to use an O-ring around the pot shaft. It adds friction, which you can vary by how far you push the knob onto the shafts. For push-pull knobs use two O-rings of different diameters, but not so different that one fits easily inside the other.
    That won't work with a push-pull, unless the looseness isn't a problem when the knob is up.
    Even looser when up. @Roland ;
    One pot is spring loaded when pushed down; the other has to be pulled up. Of the two, the spring loaded one is definitely looser.
