With strings slackened or removed, the WVPSB can shift about relative to the pivots. The other type stays in position. It just rests back against the guitar body.
If you ever decide to deactivate the vibrato by setting hard against the guitar body top, this is easy to do on the two-screw version. The adjustable range of the WVPSB depends on how deeply you set the threaded inserts. If these are low enough to enable blocking off, they may be too deeply set for normal floating use. The further the pivots extend out of the threaded insert, the greater the possibility of the pivots wobbling. This will affect tuning stability.
The single most critical factor is to drill the pivot holes absolutely vertically on a bench drill.
