Cioks stuff is great, I’ve had two (only changed due to needing more power, now have a DC10 link). The only minor issue is they use their own plug types for the connection to the power unit, but they’re solid and you get plenty with the unit, and additions are cheap enough and easy to find.
I chose it as it’s able to power an HX Stomp, when used with a parallel adapter to deliver 1A at 9v, as well as the H9. It’s also tiny.
The connections are a little annoying, as I have a tone of cables from my other PSUs, but it ships with a lot of cables and they are cheap to buy, as long as you order them from Thomann at the same time as you order the DC-7!
it seems quiet, but I am not running a ton of crazy analogue circuits. It’s incredible to think this could usurp my big MC403 power supply on my big board, if I were to buy the extension unit.
