Ok - my first ever guitar was a Dean Baby ML, which looks like this:
(except it now has cream pickup rings and burnt chrome pickup covers, but we'll gloss over that because it looks shit)
I don't play it much any more - it's been languishing in its gig bag for a while, tuned to open C and feeling rather sorry for itself. It's actually a pretty good guitar - nice neck, decent pickups etc, and I want to bring it back into use. I also have to finally pick a bone I've always wanted to pick with it - I don't like the finish and never really have. It's a sparkly metallic silver and it just looks a bit wussy. It's basically a metal guitar, but the finish is too glam and I've always thought it would look better natural or something. Hence why I'm asking for advice on stripping the finish.
The current finish (or at least the clearcoat over it) seems to chip quite easily (following the usual pointy-guitar incidents with walls etc) but I don't know how easy it would be to strip totally. It's basswood under there, I have no idea how many pieces or what the grain would be like obviously, but I have been inspired by this project I saw on sevenstring.org, with a low-end Dean that would have cost a similar amount to mine new, and would originally have been black, I think the body is basswood like mine, but IIRC could also be mahogany:
I think that looks fantastic, and I'd like to do a similar thing (or along those lines, maybe not identical) to mine if I could. I think it's stripped, then stained "English Oak", then clear-coated. What's the best way of going about stripping a finish and making it look halfway decent? I don't want to ruin my first guitar... I appreciate it's a risk I have to take, but I'd like to do a good job of it.
Any help would be greatly appreciated.
Other than that, good luck! It's hard work, you'll need to be ready to sand between coats and stuff or you'll end up with an orange peel finish like I have on my sg. But it's rewarding work, and you might find it sounds better with a thinner coat of finish on it, too.
If you don't have power tools, sand it with blocks, and coarse paper first. A good one it is 3M Fre-Cut but it's not cheap. You'll need different shape blocks/sticks for the different shapes & areas. 120 grade will cut pretty fast, then move to 180 and finer as you go, or there will be scratches. The right paper is key.
You will have to strip it somewhat. The wiring & pups can most prob stay in place, un-done and pushed into their cavities. Tape the inside of pot & switch holes. Wrap pups in tape.
Use a good tape like 3M blue, not the cream DIY rubbish... if it's hard to remove give it a quick waft with heatgun/hairdryer, comes right off then.
Power sanders can be a time saver but also a quick way to f*ck things up!
I certainly wouldn't contemplate stripping a metallic finish by sanding, they generally have to be thicker than the equivilent solid colour.
heat gun to get most of the way, then sand once the paint is out the way.
don't use a heat gun on the neck though, scrape and sand through the layers
Instagram
Many ways to skin cats, but I've sanded plenty of guitars, with the right papers it's fast enough - certainly not weeks!. never used a heatgun. Half hour to get that far is slow vs sanding with the right papers and a block/s - that's the key.
Metallic will most likely be 'base & clear'', the clearcoat should mostly come off with heatgun. The metallic will probably be ontop of a groundcoat or at least a primer, these stages are very thin and easy to sand off.
Total stripdown is not always needed, I have done several refins without needing to, but I guess with heatgun it is because of the wires etc.
However, if you were to spray a colour, or clear, or both, between each coat, you need to sand it.
I defer to others here - I know it needs to be done to avoid orange peel look, because my refin looked that way, but I don't know what grits to use. Presumably, quite fine. @wezv perhaps?
It basically just sands out any rough spots and ensures each coat is uniform.
I used plasticote to clear coat a marble finish. I can provide you with tips and method on marbling if you want, as mine was great first time (it was the clear coats that were orange peel looking!).
You might be able to get dark stained 'clear coats' to get a similar effect, too.
Reckon it's like painting itself, there's different ways that end up at the same result. I guess I'm used to sanding as a method from custom car & bike painting, sanding a guitar seems a doddle in comparison! And I have ended up with a ton of different papers and blocks. All good fun.
