The Fender TBX is not a midrange booster device. It is just a dual mode passive roll off Tone control.
The Fender mid booster devices require onboard +9volts battery power.
Are the dual coils in your “Noiseless” replacement pickups side-by-side (like a Rails pickup) or stacked vertically? The latter can be considerably taller than traditional single coil designs.
Check that the existing pickup cavities are deep enough to accommodate stacked coil pickups and have clearance for their height adjustment screws.
I see naaartheeng, Mister Fawlty. (You have posted no photographs.)
If I recall correctly, Fender N3 Noiseless pickups for Stratocaster are supplied with unusual resistance tapers for the tone controls (custom taper D250k). Audio or linear taper pots will work but they may put some unusual loading on the pickups.
If you intend to replicate the Fender Clapton signature Stratocaster circuit, it is probably wisest to follow the official schematic diagram - except, maybe, minus the TBX Tone control.
