Yes, I do take my bridges apart occasionally and scrub every individual part, including the screws, in soapy water with a toothbrush. They will end up looking like new, but the downside is that you will need to do a setup afterwards, or at least check it’s still good.
Personally i’d just take the strings off and just go in with a dry/damp toothbrush in situ.
If you dismantle and not sure what to do then yes one string at a time and then you can use the next saddle as the barometer to re-set
Not sure though why you need to take out intonation and height screws - It is a good idea from time to time to turn let/right or up/down a half turn and leave as is, just to stop them 'locking up'
In my defence against accusations of OCD cleaning; I hadn't changed the strings for 8 months! . I’m getting the nut sauce out tonight tho, so maybe I do have a problem....
I think the secret is don't let it build up.
A regular dust off with a paintbrush is far easier than a full strip down.
