My music:- https://soundcloud.com/hubobulous
Now let's wait for the price and sounds like a good solution for those that like a valve amp but have thought of going Kemper/Direct to FOH etc
Do we assume 15 watts?
EDIT: More info/responses from John Suhr and Pete Thorn over on the TGP thread:-
JS:
The clean channel has a lot of headroom, it’s a solid 16W RMS clean with big iron. Channel 3 and 2 are shared EQ the same but with independent bright switches.
PT:
Dual 6V6s
The clean channel is very similar to a Bella actually but with a master! It’s a sparkly, juicy, surprisingly high headroom clean, that will break up if pushed hard.but there’s an impressive amount of headroom and volume for a lower powered amp.
this is such a great idea!
I'd always liked the tone of the PT100 (from recordings) - but 100w is beyond over kill.
anyone know if ch2/3 can get upto JCM800 sounds, or even further with the gain?
The 100 is not massively louder in real terms because the master volume on the amp is excellent and the loop is the best I've ever owned.
I had a revolving door of high gain amps until I bought the PT50 in 2011.
It has been my main amp since then.
Who is the player? I don't know her.
If it's not silly money they should move a lot of these.
ok just checked - the Suhr Reactive Load IR is £600, I would guess the amp would be around £1500+ alone, so total around £2,200 - £2,500 ?
I can see the PT15IR hitting £3000
