I have carried out a basic set up of my jem and have reached a point where the lowest action i can get is around 1.65 mm on bottom E and around 1.4 mm top E - this is on a straight neck with around 0.10 mm relief (less than my other guitars but assume a jem can get away with a low relief).The action is at this point pretty much all the way from the 10th Fret to the 25th Fret (which i like as my others guitars tend to have a higher action at the 22nd fret than the 12th fret) -
This is generally buzz free (like to do this without guitar being plugged in rather than masking any buzz) - however one weird thing i have is with the 12th fret on bottom E. basically when pressed to fret board normally (as you would when holding down a string) there is no buzz on that fret. also tapping it hard and quick to fretboard provides a similar sound as to every other fret when i do the same.(it rings) However if i press it more softly and slower it hits the fret and makes a dull sound and does not really ring out (more like a thonky buzz sound)- is this a dead fret or is there too little relief in the neck.(it will ring out when i strike it harder and faster though)
i has assumed that the jem is designed for very low action. I am happy with the action at this point - low enough to be easy to play but still enough play to stop fingers slipping when bending etc.
I assume there is no real correct relief setting on a guitar ie my tokai les paul has around 0.20 mm relief, my strat is around 0.25 mm (i do tend to like a straight neck if i can get it)
what sort of action and relief are you getting on a pointy guitar (ie not a les paul, strat etc).
Also do most people get a set up done on their guitars. i can do a basic one which has served me well enough for now
I raised my action from 1.0 low side and 0.8 high to 1.1 either side earlier in an attempt to be reet manly there's a bit of buzz when you thwack the low e (acoustically) but then I am using 10-46 in Dstd/24.75 so I'm asking for it.
Case in point - my Squier Fat Tele goes out of tune as you go up the neck; open tuning stays fine, but when you start fretting chords, it's out of whack entirely. I've tried adjusting the intonation but it didn't do all that much...
