Removing them is simple - as well as unsoldering the wires you'll need to break or cut the rivets that were used to pinch the clips together instead of bolts, I usually do it just by jamming a large screwdriver in the gap and using brute force. You can straighten the clip afterwards with pliers if you need to. Replacement caps may be slightly - or a lot - smaller, so you'll need to improvise some means of making them fit, wrapping with tape or a bit of cut-down plastic pipe or something, and replace the rivets with nuts and bolts.
Sounds crude but you can't spend too much time and effort to do a pretty job on them, the amps aren't worth enough (sadly).
If they haven't, then someone has added the extra ones to try to 'improve' the filtering, because the amp was humming. This won't work because the problem is likely to be the caps leaking rather than just not working. If so, remove *both* sets of caps and replace them properly with 4700uF, 63V or higher. If you can use a higher voltage rating or even a slightly larger capacitance to get a larger cap which will fit better in the clamps, I would - the extra cost is more or less inconsequential if you're doing the job yourself.
