Thanks.
then you can wind the amp back a bit too
A good way of getting more headroom and less flub is the 'Stokes mod', but I've never done that on a reissue.
In that case, I'll leave well alone! Thanks for the info.
http://www.allenamps.com/trans.html
http://thefretboard.co.uk/discussion/149448/solid-state-plug-in-rectifier-and-bias-probe#latest
I had one and modded the life out of it until it didnt flub, but sounded like a JCM800, which isnt a bad thing, but if you want a JCM800 it's easier to buy one, and if you want a JTM then put up with the flub.
As pointed out turning the volume down a bit, reducing the bass and using single coils helps, but will sound very different to the thing ran flat out with humbuckers.
