https://www.andertons.co.uk/voodoo-labs-18v-y-cable-for-combining-outputs-on-pedal-power-packs-vlppy?LGWCODE=VLPPY;56375;6335&gclid=Cj0KCQiA-c_iBRChARIsAGCOpB0EH-6m4_AugZM8V6bwMN9kvZkhNoL_VKIpkEM4kQQ3RxPvviHD9mAaAq9_EALw_wcB
and 2 isolated 9v outputs will get me 18v at the current rating of one of the 9v outputs?
R.
Edit: @ICBM pointed out I had the calculation the wrong way around.
Eqd Speaker Cranker clone
It might need slightly more 9V current (maybe 180-200mA correction 650-750mA) depending on how efficient it is.
R.
Power = voltage x current, and you can’t get more power out than you put in.
R.
A series cable adapter would let 2 9v 300ma outlets double to 18v 300ma though?
A pedal tech built me a small 18v supply with a large mA to use with my Gigrig power system.
Why is the mA supply low on many isolated power supply systems? The effectrode power supply is the only high mA isolated I know. I’ve had my fair share of 500mA pedals too so why aren’t there more on the market?
Can you do that? Then you will definitely have more than 300mA
https://imgur.com/a/rdeM3Md
