When I stripped it down I did wonder whether or not it could be realigned by shimming the neck pocket. For future reference is that a route that could be considered if the pocket wasn't a tight fit?
Is it fairly common to see misalignment around the bridge?
Ever guitar that I’ve owned that had this issue I’ve been able to correct by slightly loosening the neck screws and manuvouring the neck into alignment. If the neck doesn’t stay in place then a couple strips of sandpaper at the front and back of the pocket will keep it stable.
Thanks for all the input, yet again I've learned something: )
