Refinishing a Fender neck in ‘vintage tint’
Caffeine_VampireCaffeine_Vampire Frets: 3479
edited February 2019 in Making & Modding
Pretty straightforward, I have an AV Hardtail. Period correct pale but I prefer the ‘yellow’ aesthetic of my other AV guitars.
Advice re products and doing a good job would be most welcome.
'Vot eva happened to the Transylvanian Tvist?'
  • munckeemunckee Frets: 12327
    I think northwest guitars used to do a vintage tint nitro spray, not sure if you can spray straight over existing.
    Steve Robinson - Manchester Guitar Tech - he has the stuff you need!
  • Steve Robinson - Manchester Guitar Tech - he has the stuff you need!
    Aw man, I tried Steve but it’s not something he does. Thanks though.
    I’d be surprised if the AV tint wasn’t just a standard amber nitro to be honest - every AVRI I’ve had/seen has looked identical to amber tint nitro sprayed necks I’ve done myself - is the AVRI a specific tint or something?
  • Caffeine_VampireCaffeine_Vampire Frets: 3479
    I think you’re right but just looking for confirmation and materials before starting the job. A hint or two wouldn’t go wrong either ;)
  • Rothko & Frost for nitro
  • SteveRobinsonSteveRobinson Frets: 7015
    Thanks Mark.
    I generally wouldn't advise spraying over the existing finish though, adhesion probably wouldn't be good enough. Scuff sanding right up to the frets is tricky.
    Although I suppose if it did start flaking you could always take it back to where it was by stripping off the cellulose and buffing it back to a shine?
    Bookmarked with thanks.
  • Thanks Mark.
    Hi Steve, thanks for chipping in. I’m guessing a slow, careful removal of the existing lacquer with fine wire wool/sandpaper followed by a light spraying in stages should be ok?
  • Surely if it's a nitro finish the easiest way to get it off is with solvent?
  • Spec shere from Fender -
    Model Number: 017-0177-(Color #)
    Series: Special Edition
    Body: Alder
    Neck: Maple, “C” Shape,
    (Satin Polyurethane Finish)
    Fingerboard: Maple, 9.5” Radius (241 mm)
    No. of Frets: 22 Jumbo Frets
    Scale Length: 25.5” (648 mm)
    Width @ Nut: 1.685” (42.8 mm)
    Hardware: Nickel/Chrome
    Machine Heads: Standard Cast/Sealed
    Bridge: 6-Saddle Vintage-Style Strat® Strings-Through-Body Hardtail
    Pickguard: 3-Ply Black/White/Black
    Pickups: 3 American Vintage '70s Strat Single-Coil (Bridge, Middle, and Neck)
    Pickup Switching: 5-Position Blade:
    Position 1. Bridge Pickup
    Position 2. Bridge and Middle Pickup
    Position 3. Middle Pickup
    Position 4. Middle and Neck Pickup
    Position 5. Neck Pickup
    Controls: Master Volume,
    Tone 1. (Neck Pickup),
    Tone 2. (Bridge/Middle Pickup)
    Colors: (300) 3-Color Sunburst
    (306) Black,
    (Gloss Polyurethane Finish)
    Strings: Fender® USA, NPS, (.009 to .042)
    Unique Features: Large ‘70s Style Headstock,
    ‘70s Style Decal,
    Black Dot Position Inlays,
    Black Plastic Parts,
    Dual “T” Roller String Trees
    Source: U.S.
    Accessories: Gig Bag, Cable, Strap
    U.S. MSRP: $949.99
    INTRODUCED: TBA
    DISCONTINUED:
    DISCONTINUED COLORS:
    COMMENTS:
    WRENCH SIZES: .050” Saddle Height Adjustment Wrench, p/n 0018531000
    3/32” Truss Rod Adjustment Wrench p/n 0018622000
  • Ah, I thought the AVRIs were all nitro-finished. Maybe this is a different series to the one I was thinking of.
    It’s a kind of an AV/American Special deal I think.
    Why not buy the best? https://www.manchesterguitartech.co.uk/shop/
    A polyurethane finish on the neck is authentic for a 70s guitar.
    Stripping is a horrible job but the best method is to use a scraper and Stanley blade between the frets.
  • In the Haynes Manual for the Stratocaster I think this exact thing is shown. MIJ reissue maple neck Strat, poly finish scraped off the back, frets removed and the board sanded, then refinished with poly. I can look it up when I get home if you want more info.
    Or I could just look at my own Haynes Strat manual and then give Steve a call after saying ‘DOH’ but thank you.
