If the speaker has fallen apart it will just need a new one - it won’t be worth re-coning - and probably the pots and jacks cleaned, and it should work fine.
ICBM said:
If it’s a Fane it may be printed on a small round sticker, usually bright green - these often fall off, so have a look in the bottom of the cabinet!
If you have no other way of knowing, assume 8 ohms - it’s very unlikely to be 16, and if it’s 4 then it will be safe to replace it with an 8, but not the other way round. My best guess is that it’s 8 anyway.
